Use the external-honeypot command to enable or disable prevention of authorized stations from roaming to external honeypot APs. The external-honeypot command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the external-honeypot command, run the apply command to implement the change.
| enable | Enables prevention of authorized stations from roaming to external honeypot APs. |
| disable | Disables prevention of roaming to external honeypot APs. |
The following example enables prevention of roaming to external honeypot APs:
EWC.extremenetworks.com:mitigator:scprof:scp_name# external-honeypot enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
