Use the show command to display topology configuration information.
| topology name | Displays information about the specified topology. |
The following example displays information for all configured topologies:
EWC.extremenetworks.com:topology# show Name Mode L2:VlanId,tagged,port L3:IP,GW,DHCP L3:IPv6,Auto-Generated Admin admin N/A,N/A,Admin 192.168.3.13,192.168.3.7,N/A fd66:2280:2668::0013,fd66:228:2668:0000:862b:2bff:fe60:2a8a 64;fe80:0000:0000:0000:862b:2bff:fe60:2a8a 64 Bridged at AP untagged b@ap 123,enable,N/A Port1 physical 103,disable,Port1 10.13.0.1,10.13.0.9,local Port2 physical 2,disable,Port2 10.13.1.1,none,none Port3 physical U,disable,Port3 10.0.2.1,none,none Port4 physical U,disable,Port4 10.0.3.1,none,none Seg1_Routed routed N/A,N/A,N/A 172.16.209.1,none,local Seg2_Routed routed N/A,N/A,N/A 172.16.210.1,none,local ACTT_Seg1_Routed routed N/A,N/A,N/A 10.13.16.1,none,local ACTT_Seg2_Routed routed N/A,N/A,N/A 10.13.32.1,none,local route1 routed N/A,N/A,N/A 5.5.5.5,none,local TopoFor313 b@ap 553,enable,N/A Topology global info: Internal VLAN ID: 1 Multicast support: disabled
The following example displays information for a physical topology named esa0:
EWC.extremenetworks.com:topology:esa0# show Topology mode: physical Name: esa0 3rd party: disable Layer 3 presence: enable
Print
this page
Email this topic
Feedback
