| service-uri | Specifies the provider Uniform Resource Identifier (URI). |
The Service URI must be a valid URL that starts with https://. Once you have specified the provider URI, you can issue the specific configuration commands. Use the exit command to go back to the hotspot context. From there you can issue a command to configure another service URI.
This example shows how to enter the provider-config context for a given URI:
EWC.extremenetworks.com:wlans:hs-wlan:hotspot# provider-config https://osuserver.example.com/sign-up/smartphone/index.html
After the desired changes are made, this example returns to the hotspot context:
EWC.extremenetworks.com:wlans:hs-wlan:hotspot# provider-config exit.
Print
                        this page
Email this topic
Feedback
