Use the no export command to remove the specified export file from the local or flash drive.
| filename | Specifies the file name of the export file to remove. If the export file is located on a flash drive, the string “(flash)” must be suffixed to the end of the specified file name. |
| number | Specifies the index number of the export file on the list to remove. |
The following command removes the list index 2 file from the export list:
EWC.extremenetworks.com# no export 2 EWC.extremenetworks.com#
The following command removes the export_lab213_V4R1.7.10_NAMO_ENT.zip export file from the export list:
EWC.extremenetworks.com# no export export_lab213_V4R1.7.10_NAMO_ENT.zip EWC.extremenetworks.com#
Print
                        this page
Email this topic
Feedback
