Use the show command to display the default-role configuration information for the current vnsmode:default-role context. The show command is accessible from within the vnsmode:default-role context.
None.
The following example displays the default-role configuration from within the vnsmode:default-role context:
EWC.extremenetworks.com:vnsmode:default-role# show Assigned topology: Bridged at AP untagged Ingress rate profile: Unlimited Egress rate profile: Unlimited Enable AP filtering: enable Synchronize: disable EWC.extremenetworks.com:vnsmode:default-role#
Print
                        this page
Email this topic
Feedback
