Use the show cdrs command to display a directory listing of the user‘s call detail records. Use the parameters to display the contents of the records.
| dir | Specifies the name of the directory you want to view. |
| filename | Specifies the name of the file you want to view. |
| 1-9600 | Specifies an item number from the file name list. |
The following example lists the folders containing the call detail records:
EWC.extremenetworks.com# show cdrs 20050921wed 20050922thu 20050923fri 20050929thu 20050930fri 20051103thu
The following example lists the file names within folder 20050921wed:
EWC.extremenetworks.com# show cdrs 20050921wed 1: 20050921194016.dat 2: 20050921204353.dat 3: 20050921212300.dat 4: 20050921212431.dat 5: 20050921213022.dat 6: 20050921213053.dat
The following example selects a record by file name and displays its contents:
EWC.extremenetworks.com# show cdrs 20050921wed 20050921194016.dat
    Acct-Session-Id = 4331ed220001
    User-Name = david@lab.webdomain.com
    Filter-Id = Default
    Acct-Interim-Interval = 1800
    Session-Timeout = 0
    Class = 0x5a59 670 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    Acct-Status-Type = 2
    Acct-Delay-Time = 108287
    Acct-Authentic = 1
    Framed-IP-Address = 0.0.0.0
    Connect-Info = 802.11a
    NAS-Port-Type = Wireless-802.11
    Called-Station-ID = 00:50:C2:23:A0:59
    Calling-Station-ID = 00:0E:35:CA:EC:4E
    Siemens-AP-Serial = 0122003880188006
    Siemens-AP-Name = 0122003880188006
    Siemens-VNS-Name = zone_qua
    Siemens-SSID = lab7_zone
    Acct-Session-Time = 574
    Acct-Output-Packets = 54
    Acct-Input-Packets = 558
    Acct-Output-Octets = 9814
    Acct-Input-Octets = 64865
    Acct-Terminate-Cause = 6
    Authenticated_time = Sep 21 2005 19:30:42
    Disassociation_time = Dec 31 1969 19:00:00
Optionally, the same record could be viewed by specifying its number on the filename list instead of by its filename, as follows:
