Use the tx_adjust_power command to specify an offset to the Tx power level, which is used to adjust the ATPC power levels from the calculated value. The tx_adjust_power command is accessible from most ap:defaults:ap_type:radioX contexts of the CLI.
| value | Specifies the value in dB. |
The following example sets the Tx power adjust level to 0 dB:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1# tx_adjust_power 0
Print
                        this page
Email this topic
Feedback
