Use the beaconp command to set time units between beacon transmissions. The beaconp command is accessible from all radio contexts of the CLI.
After you run the beaconp command, run the apply command to implement the change.
| 50-1000 | Specifies the number of time units (milliseconds) between beacon transmissions. |
The following example sets the time between successive beacons to 70 ms on Radio 2:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio2# beaconp 70
Print
                        this page
Email this topic
Feedback
