Use the radio2-strictlimit command to enable or disable strict enforcement of load limits on Radio2 when Radio Load Control is active. When strictlimit is enabled, any clients in excess of the configured limits on the radio are immediately disconnected. The radio2-strictlimit command is accessible from the ap:load-groups:<named-loadgroup> context.
| enable | disable | Enables or disables the strict enforcement of load limits on Radio2. |
Radio Load Control must be enabled for this radio before this command can take effect.
The following example disables strict load limiting on Radio2:
EWC.extremenetworks.com:ap:load-groups:radiogroup1# radio2-strictlimit disable
Print
                        this page
Email this topic
Feedback
