Use the led-mode command to configure the behavior of the LEDs on the Wireless AP. The led-mode command is accessible from the ap:<serial> and all ap:defaults contexts of the CLI.
| identify | All LEDs blink simultaneously approximately two to
four times every second. Note: This parameter is only available in the
<serial> context.
| normal | Identifies the AP status at all times while the AP is powered on. |
| off | Displays fault patterns only. LEDs do not light when the AP is fault free and the discovery is complete. |
| wds-signal | Indicates the WDS signal strength as a bar graph. This setting helps to align external antennas in WDS deployments by correlating the WDS link RSS with the LED pattern. Use this setting only if the AP is participating in a Mesh or WDS network. Note: This
parameter is only available in the <serial> context.
Only options normal and off are allowed in the ap:defaults contexts.
The following example turns off LED activity:
EWC.extremenetworks.com:ap:defaults:ap3935FCC# led-mode off
The following example configures the LED mode to indicate WDS signal strength:
EWC.extremenetworks.com:ap:0409920201202222# led-mode wds-signal
Print
this page
Email this topic
Feedback
