Use show stats to display throughput related statistics for the Wireless APs and for the Wireless Appliance interfaces.
Use show ap to list the serial numbers of existing Wireless APs. For more information, see show ap (AP Configuration).
| ap | Displays properties of an Wireless AP. |
| ap_serial | Specifies the serial number of an Wireless AP. |
| wired | Displays the hardwired connection. |
| wireless | Displays the wireless connection. |
| radio1 | Displays radio1 statistics. |
| radio2 | Displays radio2 statistics. |
| interface | Displays properties of a port on the Wireless Appliance. |
| interface_name | Specifies the name of a port on the Wireless Appliance. |
The following example displays statistics for the Wireless AP0001000418800008:
EWC.extremenetworks.com# show stats ap 0001000418800008 Serial: 0409920201203917 IP Address: 10.222.0.126 Clients: 1 Home: local Session start: 2008-06-18 19:30:50 Uptime: 9878.13333333 min Packets Sent: 419350 Packets Received: 936371 Bytes Sent: 110108177 Bytes Received: 428278710 Protection Mode: on 802.11b/g Ch/Tx: 2462 /15 802.11a Ch/Tx: 5200 /16
The following example displays the statistics for the same Wireless AP over its wired connection:
EWC.extremenetworks.com# show stats ap 0001000418800008 wired IP Address: 10.222.0.126 Status: approved Statistics Receive Transmit Discarded Packets 1661 0 Total Errors 0 0 Unicast Packets 645614 419231 Multicast Packets 201404 3 Broadcast Packets 90139 488 Total Packets 0 419722 Total Bytes 428661221 110236012
The following example displays the statistics for Wireless AP 0500006072051204 over the radio1 wireless connection:
EWC.extremenetworks.com# show stats ap 0500006072051204 wireless radio1 Mode: a MAC Address: 00:0F:BB:09:EC:E0 MAC Address: 00:0F:BB:09:EC:E1 MAC Address: 00:0F:BB:09:EC:E2 MAC Address: 00:0F:BB:09:EC:E3 MAC Address: 00:0F:BB:09:EC:E4 SSID: CNL-91-0-0-ssid SSID: CNL-91-0-1-ssid SSID: CNL-91-0-2-ssid SSID: CNL-91-0-3-ssid SSID: CNL-91-WDS-ssid Operational Max Rate: 54 Channel: 157:5785MHz Current Power Level(dBm): 0 IP Address: 10.91.0.50 Status: approved There are no active clients on this radio There are 1 WDS Children. Statistics Received Transmitted Discarded Packets 1 1 Errors 82519 1 Unicast Packets 0 46605 Multicast Packets 0 0 Broadcast Packets 0 0 Total Successful Packets 0 46605 Total Successful Bytes 727933 6815737 Statistics 802.11 MIB Values WEP ICV Error Count 0 WEP Excluded Count 0 Retry Count 0 Multiple Retry Count 0 RTS Success Count 0 RTS Failure Count 0 ACK Failure Count 609 Frame Duplicate Count 1 Transmitted Fragment Count 5312 Multicast Transmitted Frame Count 0 Failed Count 1 Received Fragment Count 46605 Multicast Received Frame Count 0 FCS Error Count 124944 WEP Undecryptable Count 0 Deauthentications Due to CAC 0 DCS Channel Utilization by Adjacent AP`s [%] - Average n/a DCS Channel Utilization by Adjacent AP`s [%] - Maximum n/a DCS Tx Channel Utilization [%] - Average n/a DCS Tx Channel Utilization [%] - Maximum n/a DCS Rx Channel Utilization [%] - Average n/a DCS Rx Channel Utilization [%] - Maximum n/a DCS Noise [dBm] - Average n/a DCS Noise [dBm] - Maximum n/a
The following example displays the statistics for the interface esa0:
EWC.extremenetworks.com# show stats interface esa0 Frames Transmitted: 466898 Frames Received: 673553 Octets Transmitted: 105750978 Octets Received: 131981692 Multicast Frames Transmitted: 11 Multicast Frames Received: 1419 Broadcast Frames Transmitted: 2852 Broadcast Frames Received: 1197 Pause Frames Transmitted: 0 Pause Frames Received: 0 Frame Check Sequence Error: 0 Frame Too Long Errors: 0
