Use the priority-override command to override the priority for all packets in the WLANS. The priority-override command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the priority-override command, run the apply command to implement the changes.
| enable | disable | Enables or disables priority override for all packets in the WLANS. |
The following example overrides priority for all packets on WLANS CNL-7-CP:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# priority-override enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show priority-override Priority override: enable
Print
this page
Email this topic
Feedback
