Use the upgrd command to upgrade the Wireless AP‘s software image. The upgrd command is accessible from the ap:maintenance context of the CLI.
After you run the upgrd command to upgrade the Wireless AP‘s software image, run the apply command.
| default | Specifies default upgrade. As part of the default upgrade process, when the Wireless AP registers with the controller, the AP's firmware version is verified. If it does not match with the value as defined for the default image, the AP is requested to upgrade to the default image. |
| control | Specifies controlled upgrade. The controlled upgrade allows you to individually select and control the state of a Wireless AP image upgrade. For example, you can specify which Wireless AP to upgrade, the upgrade schedule, and how to upgrade. |
The following example specifies default upgrade:
EWC.extremenetworks.com:ap:maintenance# upgrd default
The following example specifies controlled upgrade:
EWC.extremenetworks.com:ap:maintenance# upgrd control
Print
                        this page
Email this topic
Feedback
