Use this command to enable or disable the ability to ignore similar characters when generating the password pattern. The pwd-ignore-similar command is available in the wlan:<WLAN-service-name>:auth:captiveportal context.
| enable | Enable ignoring similar characters when generating the password pattern. |
| disable | Disable ignoring similar characters when generating the password pattern. |
Print
this page
Email this topic
Feedback
