Use the port command to enable or disable the port from within the appropriate port context for your platform:
| enable | Enables the port for this context. |
| disable | Disables the port for this context. |
The following example enables the ESA1 port in an l2ports:esa1# context:
EWC.extremenetworks.com# l2ports EWC.extremenetworks.com:l2ports# esa1 EWC.extremenetworks.com:l2ports:esa1# port enable EWC.extremenetworks.com:l2ports:esa1# apply EWC.extremenetworks.com:l2ports:esa1# show Port: enable EWC.extremenetworks.com:l2ports:esa1#
Print
                        this page
Email this topic
Feedback
