Use the hostname command to configure a hostname for the controller.
After you have run the hostname command, run the apply command to implement the changes.
| name | Specifies the hostname of the controller. |
| none | Removes the configured hostname. |
The following example specifies that the host name of the controller should be EWC123.
EWC.extremenetworks.com:host-attributes# hostname EWC123 EWC.extremenetworks.com:host-attributes# apply
Print
this page
Email this topic
Feedback
