Use the arp-proxy command to enable or disable the AP as an ARP proxy for this topology. Only APs to which this topology is applied are enabled/disabled as ARP proxies. The arp-proxy command is available from the topology:<named-topology>:l2: context of the CLI for b@ap topologies.
| enable | Enables the ARP proxy for this topology. |
| disable | Disables the ARP proxy for this topology. |
This example enables the ARP proxy for the test topology:
EWC.extremenetworks.com:topology:test:l2# arp-proxy enable
Print
                        this page
Email this topic
Feedback
