Use the show topology command to display the IDs and names of IP interfaces.
| l3 | Displays only topologies with an L3 configuration. The topologies are listed by index number. |
You can identify an IP using its interface name or, for short, the identifier returned by the show topology l3 command. Interface name is the name of any topology with L3 configuration (Physical, Admin, B@AC or Routed).
EWC.extremenetworks.com# show topology Name Mode L2:VlanId,port L3:IP,GW,DHCP Admin admin N/A,Admin 192.168.4.37,192.168.4.11,N/A esa0 physical 545,esa0 10.109.0.1,10.0.0.2,none esa1 physical -1,esa1 10.0.1.1,10.0.1.2,none Bridged at AP untagged b@ap -1,N/A Extreme-37Topology b@ac 647,esa0 10.209.2.37,0.0.0.0,none 777 b@ac 777,esa-1 649 b@ac 649,esa-1 650 b@ac 650,esa0 Topology global info: Internal VLAN ID: 1 Multicast support: disabled
EWC.extremenetworks.com# show topology l3 Name Mode L3:IP 1:Admin physical 192.168.4.37 2:esa0 physical 10.0.0.1 3:esa1 physical 10.0.1.1 4:Extreme-37Topology b@ac 10.10.1.1 5:CNL-209-AAA:engineering routed 172.22.2.1
