Use the custom command, within context wlan:<WLAN-service-name>:auth:captiveportal, to configure communications options for custom captive portal settings.
After you run the custom command, run the apply command to implement the changes.
| local | Sets captive portal communications options to local |
| web | Sets captive portal communications options to web |
If customized captive portal content was previously downloaded to the controller using the copy-custom command, custom can only be successfully set to local. The internal or splash authentication mode must be set for this command to be available. For more information, see mode.
The following example sets the captive portal communications options to web:
EWC.extremenetworks.com:wlans:new-wlans:auth:captiveportal# custom web EWC.extremenetworks.com:wlans:new-wlans:auth:captiveportal# apply
Print
                        this page
Email this topic
Feedback
