This section describes commands used in the publish context on a Wireless Appliance. These commands are located in the publish context of the CLI. Execute the publish command in the location context to enter the publish context.
Refer to the section “Using the RF Location Engine” in the Wireless User Guide for more information about RF Location configuration.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the publish context:
Print
                        this page
Email this topic
Feedback
