Use the timeout command to configure the time after which the web session times out. The timeout command is accessible from the web context of the CLI.
After you have run the timeout command, run the apply command to implement the changes.
| hh:mm | Specifies time in hh:mm format — hours:minutes, range 1 minute to 7 days. |
| mm | Specifies time in number of minutes, 1-59. |
The following example sets the web session timeout to one hour and 30 minutes:
EWC.extremenetworks.com:web# timeout 01:30
The following example sets the web session timeout to two hours (120 minutes):
EWC.extremenetworks.com:web# timeout 120
Print
this page
Email this topic
Feedback
