Use the add-ap-location command to enable or disable the ability to add an AP location to the redirection URL. The add-ap-location command is accessible from within the root:wlans:<named-wlan>auth>captiveportal context.
| enable | Enable adding an AP location to the redirection URL. |
| disable | Disable adding an AP location to the redirection URL. This is the default. |
This command is only available when the authentication mode is Firewall Friendly External Captive Portal. For more information, see captive portal authentication mode. You must also specify a Redirection URL.
The following example enables adding an AP location to the redirection URL.
EWC.extremenetworks.comwlans:ffecp:auth:captiveportal# add-ap-location enable
Print
this page
Email this topic
Feedback
