Use the schedule_upgrade context to access the commands for scheduling an upgrade and back up of the controller‘s software. The schedule_upgrade context is accessible from the root context of the CLI.
schedule_upgrade is not the command. It is the context. You must be in the schedule_upgrade context to access the commands for scheduling the upgrade and backup of the controller‘s software. The commands for scheduling the upgrade and back up of the controller‘s image are provided in the following sections.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the schedule_upgrade context:
Print
                        this page
Email this topic
Feedback
