Use the clock command to set the system time.
The Network Time Protocol must be disabled before this command can be used. For more information, see ntp.
After you run the clock command, run the apply command to implement the changes.
| hh | Specifies the current hour (in 24 hour clock format) |
| mm | Specifies the current minute |
The following example sets the system time to 12:01pm:
EWC.extremenetworks.com:time# clock 12:01
Print
this page
Email this topic
Feedback
