Use the guestportalprefix command, within context wlan:<WLAN-service-name>:auth:captiveportal, to configure the user ID prefix for the guest portal access account.
After you run the guestportalprefix command, you must run the apply command to implement the changes.
| prefix | Specifies the maximum number of hours for the session time of the guestportal access account |
The guestportal authentication mode must be set for this command to be available. For more information, see mode.
The following example sets the guest portal prefix to the string “TEST”:
EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# guestportalprefix TEST EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# apply EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# show guestportalprefix guestportalprefix TEST
Print
this page
Email this topic
Feedback
