Use the add-ospf-interface command to create a <named-ospfinterface>. The add-ospf-interface command is available from the ip:ospf:ospfinterface context of the CLI.
The add-ospf-interface command is available to the physical topology and the b@ac topology with the layer 3 interface configured. The ospf interface name must be created as a physical or b@ac topology in the topology context beforeyou execute this command.
| ospf interface name | Specifies the name for the new ospf interface. The name must already be created as a physical or b@ac topology in the topology context. |
The following adds an ospfinterface with the name top1:
EWC.extremenetworks.com:ip:ospf:ospfinterface# add-ospf-interface top1
Print
                        this page
Email this topic
Feedback
