Use the adhoc command to enable or disable removal of network access from clients in adhoc mode. The adhoc command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the adhoc command, run the apply command to implement the change.
| enable | Enables removal of adhoc clients on this profile from network access |
| disable | Disables removal of adhoc clients on this profile from network access |
The following example enables ad hoc client removal:
EWC.extremenetworks.com:mitigator:scprof:scp_name# adhoc enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
