Use the aplist command to add or remove APs to and from the logs collection list.
After you run the aplist command, run the apply command to implement the change.
| add | delete | Add or delete the (following) APs from the logs collection list. If you omit these options, by default all APs in the scan profile are replaced with the APs listed in this command. |
| serial[, serial]* | Specifies the Wireless AP by their serial numbers that are to be added to the log collection list. They can be added or deleted individually, or listed as a comma and space separated list. |
Use the add or delete option add or remove APs to/from the logs collection list. You can replace the APs listed in the collection list by omitting the add or delete option, and listing the APs you want.
The following example adds a Wireless AP with a serial number:
EWC.extremenetworks.comap:logs# aplist [(add|delete)] <serial[ serial]*>
Print
                        this page
Email this topic
Feedback
