Use the frag command to set the fragmentation threshold, which is the maximum size of a packet or data unit that can be delivered. Any data above this threshold is fragmented into packets that are less than or equal to this limit. The frag command is accessible from all radio1 and radio2 contexts of the CLI.
| value | Specifies the maximum size, measured in bytes, of any packet fragment for delivery. The value range is 256 to 2346. |
The following example sets the fragmentation threshold to 1500:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio2# frag 1500
Print
                        this page
Email this topic
Feedback
