Use the analysis command to enable the Analysis Engine. Use the no form of the command to disable it. The analysis command is accessible from the mitigator context of the CLI.
After you enable or disable the Analysis Engine, run the apply command to implement the changes.
None
The following command enables the Analysis Engine:
EWC.extremenetworks.com:mitigator# analysis EWC.extremenetworks.com:mitigator# apply
Print
                        this page
Email this topic
Feedback
