Use the spoofed-ap command to enable or disable prevention of any station using a spoofed AP. The spoofed-ap command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the spoofed-ap command, run the apply command to implement the change.
| enable | Enables prevention of access to a spoofed AP. |
| disable | Disables prevention of access to spoofed APs. |
The following example enables prevention of access to spoofed APs:
EWC.extremenetworks.com:mitigator:scprof:scp_name# spoofed-ap enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
