Use the show command to display the settings for the scan profile. This show command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
None
The following example displays the scan profile scp_name‘s settings:
EWC.extremenetworks.com:mitigator:scprof:scp_name# show Profile Name: scp_name Security Scan: enable Interference Classification: disable External Honeypot: disable External Friendly: enable Internal Honeypot: disable Spoofed AP: disable Drop Frames FAF: disable Adhoc mode removal: disable DoS attacks removal: enable Blacklisting timer: 900 Concurrent Channel Number: 1 channels 1,3,5 aplist 1000005380080166
Print
                        this page
Email this topic
Feedback
