The <named-site> command, where <named-site> refers to the name of a given site, provides access to the site:<named-site> context.
The site:<named-site> context provides commands for the configuration of the <named-site>. A <named-site> must first be created using the create command in the site context. Once created it becomes available as a command, allowing access to the site:<named-site> context for that site. For example, to enter the <named-site> context for the site named site1, use the command site1 from the site context, created using the create <site-name> command.
After you have completed configuration changes for a <named-site>, you must run the apply command before exiting the site:<named-site> context to implement the changes.
The following commands are available in the site:<named-site> context.
Print
                        this page
Email this topic
Feedback
