Use the external-friendly command to enable or disable prevention of authorized stations from roaming to external friendly APs. The external-friendly command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the external-friendly command, run the apply command to implement the change.
| enable | Enables prevention of authorized stations from roaming to external APs. |
| disable | Disables prevention of roaming to external APs. |
The following example enables prevention of roaming to external APs:
EWC.extremenetworks.com:mitigator:scprof:scp_name# external-friendly enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
