Use the gateway-ipv6 command to specify an IPv6 gateway IP address. The gateway-ipv6 command is available from the topology:<named-topology>:l3 context of the CLI for the Admin topology only.
| A:B:C:D:E:F:G:H | Specifies the gateway IPv6 address. |
| none | Clears the gateway IPv6 address. |
The following example defines the gateway IPv6 address:
EWC.extremenetworks.com:topology:Admin:l3:# gateway-ipv6 fd66:2280:2668::2
Print
                        this page
Email this topic
Feedback
