Use the wins command to specify the IP address for the Windows Internet Naming Service (WINS) server. The wins command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies. This command is visible only when mode is set to local. See mode.
After you run the wins command, run the apply command to implement the changes.
| WINS server [,WINS server [...]] | Specifies the qualified IPv4 IP address or name of one or more WINS servers. |
| none | Clears the IP addresses and indicates that no WINS server is present. |
The following example specifies the IP addresses of two WINS servers:
EWC.extremenetworks.com:topology:r1:l3:dhcp# mode local EWC.extremenetworks.com:topology:r1:l3:dhcp# wins 192.168.1.3, 192.168.1.4 EWC.extremenetworks.com:topology:r1:l3:dhcp# apply
Print
                        this page
Email this topic
Feedback
