Use the flex-client-access command to enable or disable flexible client access to the wireless medium. The flex-client-access command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the flex-client-access command, run the apply command to implement the changes.
| enable | disable | Enables or disables flexible client access to the wireless medium. |
The following example enables flexible client access to the wireless medium:
EWC.extremenetworks.com:wlans:test:qos-policy# flex-client-access enable EWC.extremenetworks.com:wlans:test:qos-policy# apply EWC.extremenetworks.com:wlans:test:qos-policy# show flex-client-access Flex client access: enable
Print
this page
Email this topic
Feedback
