Use the foreign-ip command to specify the IP address and subnet mask of the foreign controller. The foreign-ip command is available from the topology:<named-topology>:l3 context of the CLI for b@ac and routed topologies.
| A.B.C.D/0-32 | Specifies the IP address and subnet mask. |
The foreign-ip command is not available when a controller is in standalone mode.
Once an availability pair is established between two controllers, the foreign-ip command is only visible after "sync" is enabled.
The following example specifies the IP address and mask of the foreign controller:
EWC.extremenetworks.com:topology:r1# sync enable EWC.extremenetworks.com:topology:r1# l3 EWC.extremenetworks.com:topology:r1:l3:# foreign-ip
Print
                        this page
Email this topic
Feedback
