Use the secure-tunnel-lifetime command to enable or configure the lifetime (the number of hours the tunnel remains enabled) of this tunnel. The secure-tunnel-lifetime command is accessible from the site:<named-site> context.
| hours | Specifies the number of hours the tunnel will remain enabled. |
The secure-tunnel command must be enabled before the secure-tunnel-lifetime command can be run. The default is 10 hours. When this value expires, the tunnel becomes disabled. Use the secure-tunnel disable command to terminate a tunnel.
The following example enables a secure tunnel for 20 hours:
EWC.extremenetworks.com:site:site1# secure-tunnel-lifetime 20
Print
                        this page
Email this topic
Feedback
