Use the delete command to delete a topology object. The delete command is accessible from the topology context of the CLI.
You cannot delete the Admin topology. Also, you cannot delete a topology that is in use by a policy.
| topology name | Specifies the name of the topology to delete. |
The following example deletes the topology named test:
EWC.extremenetworks.com:topology# delete test
Print
this page
Email this topic
Feedback
