Use the show command to display information about a topology. The show command is available from the topology:<named-topology> context of the CLI for Admin, b@ac, b@ap, physical, and routed topologies.
None
The following examples shows configuration information for the Admin topology:
EWC.extremenetworks.com:topology:Admin# show Name: Admin
The following example shows configuration information for a b@ac topology:
EWC.extremenetworks.com:topology:BridgedAC2# show Synchronize: disable Name: BridgedAC2 Layer 3 presence: disable
The following example shows configuration information for a b@ap topology:
EWC.extremenetworks.com:topology:BridgedAP2# show Synchronize: enable Name: BridgedAP2
The following example shows configuration information for a physical topology:
EWC.extremenetworks.com:topology:esa0# show Name: esa0 3rd party: disable
The following example shows configuration information for a routed topology:
EWC.extremenetworks.com:topology:r1# show Topology mode: routed Synchronize: enable Name: r1
Print
                        this page
Email this topic
Feedback
