Use the move command to update the priority of a filter rule by moving the rule from its current position in the filter list (source) to a different list position (up or down). The move command is accessible from within the role:<named-role>:acfilters and role:<named-role>:apfilters contexts.
| src-pos dest-pos | Specifies the current (source) position in the filter list of the rule to be moved, followed by the new (destination) list position for the filter rule. Valid values are from 0 -255. List position 1 is top priority. |
The following example:
EWC.extremenetworks.com:role:p1:acfilters# move 2 1 EWC.extremenetworks.com:role:p1:acfilters# show Enable AP filtering: disable filter 1 proto udp 192.168.10.0 255.255.255.0 port 10 2000 both allow filter 2 proto tcp 192.168.10.0 255.255.255.0 port 10 2000 both allow filter 3 (default) proto none 0.0.0.0 all_ports both deny EWC.extremenetworks.com:role:p1:acfilters#
Print
                        this page
Email this topic
Feedback
