Use the import command to import the controller‘s configuration from a file that was earlier exported from a previous platform or an old software release. If you want to import the controller‘s data from a remote FTP or SCP server, you must use the copy configuration command. For more information, see copy. Use the no import command to remove the specified file from the local or flash drive.
| filename | The name of the .zip or .cli file that contains the controller‘s configuration. If the export file is located on a flash drive, the string “(flash)” must be suffixed to the end of the specified file name. |
| number | Specifies the index number of the import file. You can use the show import command to find the restore file‘s index number. |
The following command imports the controller‘s configuration from a ‘zipped‘ .zip file that was exported from the previous platform or from the older software:
EWC.extremenetworks.com# import lab-213-g.11042008.141154.zip
The following command removes the controller‘s import configuration, CDRS, logs, audit information file:
EWC.extremenetworks.com# no import lab-213-g.11042008.141154.zip
Print
                        this page
Email this topic
Feedback
