Use the multicast-support command to configure multicast support for a physical topology. The multicast-support command is accessible from the topology context of the CLI.
| physical topology name | Specifies the name of the physical topology to have multicast support. |
| none | Disables multicast-support. |
This example enables multicast support on the phy1 topology:
EWC.extremenetworks.com:topology# multicast-support phy1
This example disables multicast support for the topology context:
EWC.extremenetworks.com:topology# multicast-support none
Print
                        this page
Email this topic
Feedback
