Use the band-preference command to enable or disable this site as a band preferencing load group. Refer to the Wireless User Guide for a detailed description of radio band preferencing.
The band-preference command is accessible from within the site:<named-site> context.
| enable | disable | Enables or disables band preferencing for this site. |
The following example enables band preferencing on site1:
EWC.extremenetworks.com:site:site1# band-preference enable
Print
                        this page
Email this topic
Feedback
