As of Release 9.21, you can access Layer 3 on a b@ac topology when l3presence is disabled. For releases prior to 9.21, you must enable Layer 3 on a b@ac topology to access Layer 3 commands in the topology:<named-topology>:l3 context. Use the l3presence command to enable or disable Layer 3 on a b@ac topology. The l3presence command is available from the topology:<named-topology> context of the CLI for b@ac topologies.
| enable | Enables Layer 3. |
| disable | Disables Layer 3. |
The following example enables Layer 3 on a b@ac topology:
EWC.extremenetworks.com:topology:bridged_ac1# l3presence enable
Print
                        this page
Email this topic
Feedback
