Use the wpa-v1 command to configure the WPA v1 encryption protocol. The wpa-v1 command is accessible from the wlan:<WLAN-service-name>:priv context of the CLI.
After yourun the wpa-v1 command, run the apply command to implement the name change.
| auto | tkip | none | Specifies the WPA v1 encryption protocol |
The wpa-v1 command is available when the privacy mode is set to wpa or wpa-psk. For more information, see mode.
The following example displays the WPA v1 encryption protocol, sets the WPA v1 encryption protocol to TKIP, and displays the setting:
EWC.extremenetworks.com:wlans:test:priv# show wpa-v1 WPA v.1 encryption is not enabled EWC.extremenetworks.com:wlans:test:priv# wpa-v1 tkip EWC.extremenetworks.com:wlans:test:priv# apply EWC.extremenetworks.com:wlans:test:priv# show wpa-v1 WPA v.1 encryption:
Print
                        this page
Email this topic
Feedback
