Use the show command to display Layer 3 information. The show command is available from the topology:<named-topology>:l3 context of the CLI for Admin, b@ac, physical, and routed topologies.
None
The following example displays Layer 3 information for a physical topology:
EWC.extremenetworks.com:topology:esa0:l3# show Interface IP 10.109.0.1 255.255.255.0 AP Registration: enable Allow management traffic: disable Factory default certificate/key MTU: 1500
The following example displays Layer 3 information for a b@ac topology:
EWC.extremenetworks.com:topology:bridged_ac1:l3# show Interface IP 0.0.0.0 0.0.0.0 AP Registration: disable Allow management traffic: disable Factory default certificate/key Strict Subnet Adherence: enable MTU: 1436
Print
                        this page
Email this topic
Feedback
