Use the reset command to reset configuration settings on the Wireless Appliance to their factory.
| license | Removes the installed license. |
| mgmt | Resets the management port configuration. |
EWC.extremenetworks.com# reset WARNING: Resetting will clear all configuration except for the management port configuration. It will disconnect any clients currently using the system. Following the reset, the system will be rebooted. Do you wish to continue? (y/n)The following example resets all configuration settings on the Wireless Appliance including the management port configuration. You are prompted to confirm if you want to continue to reset the Wireless Appliance:
EWC.extremenetworks.com# reset mgmt WARNING: Resetting management will clear all configuration including the management port configuration. It will disconnect any clients currently using the system. Following the reset, the system will be rebooted. Do you wish to continue? (y/n)The following example removes installed licenses and resets all configuration settings on the Wireless Appliance including the management port configuration. You are prompted to confirm if you want to continue to reset the Wireless Appliance:
EWC.extremenetworks.com# reset license WARNING: Resetting the license will
                      clear all configuration and permanently delete any installed licenses. It will
                      system will be rebooted. Activation key string :
                      XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX Capacity Enhancement Option
                      Keys: Radar License Keys: Do you wish to continue? (y/n) n
                      Reset license cancelled by user request.
