Use the friendly-ap command to add, update, or remove a friendly AP. APs are identified in this context by their BSSID (Basic Service Set ID), which is the same as their MAC address. The friendly-ap command is accessible from the mitigator:maintenance context of the CLI.
After you run the friendly-ap command, run the apply command to implement the change.
| bssid | The MAC address of the AP. |
| ssid string | An optional alphanumeric character string identifying the subsystem (SSID). |
| desc string | An optional alphanumeric character string describing the AP. |
| delete | Removes the AP identified by the BSSID from friendly AP status. |
The following example adds friendly AP “testing” by its BSSID: 11:11:22:22:33:33 on channel 5:
EWC.extremenetworks.com:mitigator:maintenance# friendly-ap 11:11:22:22:33:33 ssid testing channel 5 desc testing EWC.extremenetworks.com:mitigator:maintenance# apply
The following example deletes an AP with BSSID: 11:11:22:22:33:33 from friendly status:
EWC.extremenetworks.com:mitigator:maintenance# friendly-ap 11:11:22:22:33:33 delete EWC.extremenetworks.com:mitigator:maintenance# apply
Print
                        this page
Email this topic
Feedback
